Water pump going bad?
I have an '85 305 SB chevy that has been running about 235-240* this summer where last summer it ran 190*. I have only driven the car less than 2000 miles so it cannot be worn out. I have changed the T'stat, both fans come on at 190 or when the AC is on, I have all my air dams/deflectors in place and there is no obstruction between the condenser and radiator. I also have 60/40 water-antifreeze in the rad. and the engine oil is fresh.
What I want to know is: Can the water pump be going bad and not have the little "tell-tale" leak at the bottom of the pump?
thanks for your help,
James
'84Z28/'92 305TPI
'92 complete rear suspension/PBR disc/Posi/3:42
Light weight 34.5mm stabilizer bar in front ($10 from wrecking yard)/
"wonder Bar" ($5 from wrecking yard)
23mm sta. bar in rear
Rear RS Springs (slightly softer than my Z28)
comp cam, flowmaster
TB coolantbypass/shutoff valve to heater core
powersteering cooler lines (liberated from another wrecked car of course)
MAT relocated
Ram-Air(home-made) gutted air-box
IROC ground effects/wheels GY245/50's
700R4 superior shift kit/ corvette servo(excellent shift kit btw)
home-made strut tower brace (cost $6)
Rebuilt engine and transplanted it myself.
Love this engine!
freshly painted OCT. 2000 Teal with two white stripes on the hood and deck lid
LOW performance people should drive low performance vehicles!
James
'84Z28/'92 305TPI
MAT relocated
Love this engine!
Car: yep
Engine: uhuh
Transmission: sure does
Yes, they can be bad without leaking at the weep hole.
I've seen them come in rattling and the pulley wobbled but no leak...
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
