milling heads
Old Apr 16, 2005 | 06:04 AM
pawcio's Avatar
Car: GTA 89
Transmission: TH700
Axle/Gears: BW 9 bolt
milling heads
Hi
I have a set of L98 aluminium heads (casting 113) on my stock TPI motor from Vette 89. How much can I take off from heads for raise compression ratio without clearance problem between valves and pistons ?
camshaft and valve train it stock...head gaskets are Felpro 7733PT2.
Thanks for help
regards
Old Apr 16, 2005 | 06:17 AM
ede's Avatar
ede
a lot more than you can before you have problems with warpage and leaks
Old Apr 18, 2005 | 01:50 PM
pawcio's Avatar
Car: GTA 89
Transmission: TH700
is there any markings on heads for limit the milling ?
Old Apr 18, 2005 | 02:14 PM
ede's Avatar
ede
no
Old Apr 18, 2005 | 02:25 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Only take the minimum amount necessary to ensure a true surface... If you want to raise compression ratio, use different pistons...
Old Apr 18, 2005 | 05:07 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
GM recommends a max .060" flat mill limit for all the small block assembly line heads.
Usually that will get you pretty close to the intake valve seat anyways. Better to deck the block to raise compression ratio and improve quench clearance at the same time.
On a 350 you can achieve way over 12:1 compression using a combination of block decking, head milling and head gasket selection, using flat top pistons. No need for a domed piston.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
