manifold trouble
Old Apr 17, 2005 | 09:39 PM
thomas_iroc's Avatar
manifold trouble
i put a 350 in my 86 camaro and the oil stick is in the way of manifold what can i do?
Old Apr 17, 2005 | 09:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Get headers. If your car is a LG4 especially, the manifolds will choke it. They're already the bottleneck for the 305.
Old Apr 17, 2005 | 09:54 PM
headers
want te headers go a the same way? if it does the pipe will be in the way. the 305 dipstick is on the passanger side the 350 is on the drivers side.
Old Apr 17, 2005 | 10:27 PM
manifold
has any one else had this ploblem? what did you do?
Old Apr 18, 2005 | 12:18 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: manifold trouble
Not using the 350 exhaust manifolds?
Old Apr 18, 2005 | 03:12 PM
don't have them
Old Apr 18, 2005 | 03:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
what did you do?
I put in headers.
No the headers aren't in the way; the oil dipstick comes up between the tubes, and the dipstick completely misses the flange. Fits right in there like it was made to.
Wouldn't matter if the 350 came with manifolds or not; I don't think that any manifolds that will co-exist with the dipstick, will also co-exist with the chassis.
Get headers.
Or, you can choke the life out of your new motor, and use the 305 manifolds, and a Lokar flexible dipstick; and then your 350 will run about like your 305 does. Except it will have somewhat more grunt at very low RPMs (like less than 2000), and run out of breath at an even lower RPM (like about 3500).
Old Apr 18, 2005 | 04:07 PM
Damon's Avatar
Lokar makes a flexible (braided steel hose) dipstick kit for SBCs that have the dipstick coming out of the driver's side block deck surface . I'm told that someone around here used it in a situation like yours (I've never tried it myself).
You'll never get the solid metal tube dipstick to bend enough to clear a stock 3rd gen manifold. You'll end up kinking it every time and it still won't clear.
Or..... like everyone else said, headers!
Old Apr 18, 2005 | 06:40 PM
i have all ready got the dipstick first then i though of i will get headers now thanks
sailtexas186548
Feb 17, 2017 03:07 PM
Chas91Z28
Oct 22, 2015 10:12 AM
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
