No Fuel To Carb ?
Old Apr 18, 2005 | 11:48 AM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
No Fuel To Carb ?
any ideas on this? after car sits for a couple of weeks it wont start. all fuel lines are dry. i have to pull line off carb and fill it up so it will prime. could it be siphoning back to the tank if i have front of car on jacks for a long time? its an 86 with 350, mech fuel pump and all fuel lines except feed to carb are just vented.
Old Apr 18, 2005 | 06:50 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: No Fuel To Carb ?
Originally posted by SPIKE. mech fuel pump and all fuel lines except feed to carb are just vented.
Is you're gas cap secure? Do you even have one?
... make sure you plug the fuel return line. The only vented line should be the vapor canister's.
Old Apr 20, 2005 | 07:11 AM
SPIKE's Avatar
Car: 86 CAMARO
have gas cap but it is old so i will replace it. will plug return line. thanks.
Old May 5, 2005 | 02:31 PM
SPIKE's Avatar
Car: 86 CAMARO
in case any one was wondering. fuel pump was shot. noticed fuel spitting out of little holes on top of fuel pump. pulled apart and noticed diaphram rotted. strange thing is once reprimed it still put out 7 psi. so i bought a new holly. problem solved.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
