How much power can stock lower end take?
Old Aug 3, 2001 | 11:16 AM
nebulous's Avatar
Car: 91-Trans Am-WS6
Engine: L05 350 - ATI 9psi
Transmission: Pro-Built:Street/Strip
Ive got 60k miles on my 305 TPI. 20k of that was mildly supercharged(6psi). So, two questions: When should I start to worry about lower end rebuilding, and how much power can a stock 305 lower end take, without upgrades?
Old Aug 3, 2001 | 11:44 AM
sleeper's Avatar
You should have had thicker head gaskets installed with the supercharger. These lower the compression on the engine to prevent it from throwing rods.
The stock lower end will be ok as long as you don't beat on it all the time.
Old Aug 5, 2001 | 12:36 AM
nebulous's Avatar
Heh, well I dont beat on it with a stick or anything, but I am something of a leadfoot, and dont turn down races when they are offered to me. As far as rod throwing, the supercharger was too mild for me to worry about. I did blow the headgaskets early though(at least I thought so at about 50k miles), the supercharger certainly adds more strain. If I ever get an engine that I am happy with, as far as stability goes, then I still plan on 12-15 intercooled psi, in which case it would be wise on my part to lower compression down to about 9:1.
Jeremys87
Jul 14, 2022 09:08 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
