Why did they switch from single to duel fans???
Old Aug 5, 2001 | 12:51 AM
james_fearn's Avatar
My car originally came with a 305 TPI and a single fan. Why did they eventually go with a duel fan setup for TPI cars. I don't have any overheating issues, but then again my AC isn't functional right now. I purchased a duel fan setup in anticipation of cooling issues. Does the duel fan setup have better cooling properties and what are the benifits of the duel fan setup. I know that my charging system might not like the load from them but I'm sure there are some issues that I am not aware of as to why the dual fans are better.
James
1985 Z-28, 350 TPI, T-Tops, edelbrock 6085 heads, ZZ4 cam, accel base/runners & 24 lb/hr inj., ported plenum, everything gasket matched, crane AFPR, SLP 1 5/8 headers, single 3" flowmaster catback, 3" Catco cat, modified tranny, 165 ECM & ARAP code, MSD 6AL/wires, edelbrock STB, Spohn SFC, GW "wonderbar"
Old Aug 5, 2001 | 02:09 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
the reason for that aside from more total cfm capabilities, is allowing a small fan to run with the a/c on which draws less power than the one big fan. this in turn allows for better gas milage and less strain on the alternator. both fans only would then come on when temperature reaches a setting of too hot.
tglennon11
Sep 23, 2015 05:30 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
