Need help with power steerimg after header install
Old Aug 3, 2001 | 09:15 PM
nelliesIroc's Avatar
I just installed Hedman headers and I am having difficulty getting the power steering brackets back on. The bracket that bolts on the side of the head with the two header bolts won't fit anymore. I am looking for ideas how to get the brackets back on or how did those of you with headers get your pumps to work?
Old Aug 4, 2001 | 12:54 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
They make special brackets for header installs.
You can also "shim and balance" as we call it and use spacers, shims, etc. to do the same thing.
I welded up my own bracket for the job, I have all working A/C and P/S brackets on with headers.
I would give summit a call.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Aug 4, 2001 | 11:13 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'm lazy...
I use pieces of thick 7/16" inner diameter tubing to make spacers such that the header flange plus the spacer equalled the thickness of the manifold, then used the stock hardware and bolted it all on.
I also have working A/C and PS, with all the brackets and hardware properly installed. Nothing is loose or out of line or anything. I test fit it before the otor went in the car, I think it took about 10 or 15 minutes to get it perfect.
ICON Motorsports
Old Aug 4, 2001 | 11:23 PM
Does anyone know who would make a bracket to mount the pump without having to connect to the header flange? Or a fairly easy way to get the stock ones to work?
Old Aug 5, 2001 | 11:54 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Do as RB said and just install the bracket up on the engine, and fill the gaps with a spacer and a longer bolt.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Vintageracer
Jan 10, 2020 05:33 PM
Wesly_66
Aug 26, 2015 09:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
mdtoren
Aug 16, 2015 05:45 PM
drathaar907
Aug 6, 2015 04:20 PM
