Engine oil blowback??
Old Apr 18, 2005 | 10:48 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
The last time I checked my oil I noticed that some oil had come out of the dip stick tube and gotten on the top of the dip stick. It has also kind of stained the top of the dip stick. I have an open element with a push in breather in the valve cover where the old breather used to connect to the air cleaner. On the other side I have the PCV valve in the stock location. What do you think is going on? Blowback? Is this bad?
Old Apr 18, 2005 | 11:38 PM
sellmanb's Avatar
Car: '86 Berlinetta
It's typically referred to as blow-by, but whatever lol.
Typically blow-by will shoot your dipstick out of the tube if there's enough pressure there to shoot it out. If you got some cheap-o chrome dipstick tube, then it's more likely to happen.
The most common reason for excessive blow-by is bad piston rings.
89GTAOz
May 16, 2020 09:31 AM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
