AC Blower motor Question.......
Old Aug 1, 2001 | 08:49 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
How can I make my blower motor blow more powerful? My AC is ice cold, but with the switch on high, it just isn't that powerful. None of my ducts are leaking. Can I install a more powerful blower motor, like one out of a 4th gen?¿
It just seems like alot of other cars I have had blew alot better. My 88 GTA was the same way and so was my 87 T/A (WEAK!). There has to be a fix for this.
Thanks guys!
Mike
(Gran Turismo Americano) "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber).
Old Aug 1, 2001 | 09:00 PM
snakeskinner's Avatar
Me and a couple guys at work have been looking at this. We have several new body style Grand Prix blower motors which put out about 3 times the air of our blower motors. A guy found the wiring he needed but when he went to put it in, he found out this blower is a lot bigger and would require cutting up the a/c housing so he scrapped the idea. I havn't done anything since. If you don't mind cutting up the housing, they will work but I don't know of a bolt-in.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
73 bronco
2000 Ducati 996 Monoposto
Old Aug 1, 2001 | 09:13 PM
Engine: ZZ4 - 350
Hey Snakeskinner, to bad they are bigger, or that would be an easy fix! But I don't want to cut up the car. There has to be a more powerful blower motor that will work. I can't believe that with the way these things blow stock,that there isn't alot of people complaining.
later
Mike
Old Aug 1, 2001 | 09:15 PM
Engine: ZZ4 - 350
Hey GMTech, are ou out there??? Maybe you would know.
Old Aug 1, 2001 | 10:18 PM
clewis's Avatar
Car: 1985 IROC-Z
Engine: 305 Tuned Port Injection
If you get a positive response to this one, I'd like to know as well. I agree, there has to be a blower motor that works better than the ones we've got. I've often thought the same thing, just never did anything about it. We really should be complaining, long and loud.
Old Aug 2, 2001 | 06:55 AM
Engine: ZZ4 - 350
Well at least I know that I am not the only one with this problem. I searched through all the tech articles searching for a cure to this problem, but had no luck. I thought at one time on this board someone posted about putting a 4th gen blower in, and it made a big difference, and bolted right in. But it was a couple of months ago, and I can't find that post anymore. God knows in Florida here, I need more air flow.
Later
Mike
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Aug 2, 2001 | 04:23 PM
Greg90iroc's Avatar
you could do it many ways. with the AC on max it blows fine for me. but that has smaller resistors that allow for more current into the blower motor. you could wire up a swich and a relay with no resistors that allow higher curent to reach the blower motor. another option is to weld up a higher output motor to the blower mounting plate or you could just jbweld it. but that is not going to solve a thing unless you get more power to it. another option is to get a little jap car electric ram air setup and mount it to the blower houseing that would blow some serious air. it would be expensive though.
90 IROC l98
last season best corected 13.62 @102
mods
full exhaust, AFPR, pulley, jet stage 1 chip, billet servo, 52mm throttle body, slp runners and some 1.6 RR's and a few other little things.
243 RWHP and 342 RWTQ with hot engine and 90 octain fuel
Old Aug 5, 2001 | 05:32 PM
Jason Welch's Avatar
This goes out to west coast gta man. Wouldnt mind geting together on some things. I live in the same town and already replaced one blower in mine.
92 Firebird
305 tbi 5spd
straight pipes
Old Aug 5, 2001 | 06:18 PM
Engine: ZZ4 - 350
Hey Jason, sounds good man! Good to see another Firebird Brother out there in my neighborhood! I just emailed you
talk to you later
Mike
Old Aug 5, 2001 | 06:50 PM
camaro6spd's Avatar
hummm, my motor won't work on high at all, you are saying that if I ran a wire right to the motor from the high switch then it would work??? I won't melt the switch will I??
Old Aug 5, 2001 | 07:47 PM
Engine: ZZ4 - 350
Hey Camaro 6 speed, check the High blower Relay. I had that go on my 88 and my 87, and it caused me to have no high blower. You can jump it to check it. If I remember correctly it is right near the accumulator near the firewall. Hope this helps you a little. I believe it is cheap also, around $12
Later
Mike
Old Jun 2, 2002 | 10:38 AM
dwish8990's Avatar
so has anyone figured out what we can do to get the AC to blow harder? A blower motor from another car or what? Gotta find a good solution to this before the temp hits 95-100 in jersey.
Old Jun 2, 2002 | 10:56 AM
Engine: ZZ4 - 350
Not yet man, but there has got to be something we can do to make the system blow more powerful! It is driving me crazy.
Later
Mike
Old Oct 1, 2002 | 06:52 PM
tommygun's Avatar
Car: 1992 Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 3.23 Posi
Since the last post was a while ago, I thought I'd check up on the status of a better motor. Has anyone heard anything more about an improved blower motor? Thanks.
Old Oct 1, 2002 | 08:55 PM
Engine: ZZ4 - 350
Hey TommyGuns, I sure hope someone out there has an answer for us!
Later
Mike
Frozer!!!
Jan 19, 2024 04:55 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
