Coil question,,,these extra wires are pissing me off !!!
Old Apr 20, 2005 | 09:33 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
I just converted to an open element and had to relocate the coil as it was mounted on the intake manifold right in front of the distributor. There are two sets of small wires with clips that run from the bottom of the distributor to the side of the coil and they are short and preventing me from getting the coil very far from its original spot. My question is what are these wires? Has anyone upgraded to a better coil and done away with these wires? I want this MSD coil but I’m not seeing any spot to plug wires into it. Whats the deal, and where is a good safe place and how to mount a new coil.
Old Apr 20, 2005 | 12:14 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Re: Coil question,,,these extra wires are pissing me off !!!
Just lenghthen the white and pink wires that go to the Distributor from the old coil that are shown in this pic. This way you can relocate the coil.
Attached Thumbnails Coil question,,,these extra wires are pissing me off !!!-coil-2.jpg
Old Apr 20, 2005 | 12:16 PM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Cut the plug off the other Pink and white wires and attatch them to your new coil. White = neg, Pink = +
Attached Thumbnails Coil question,,,these extra wires are pissing me off !!!-coil.jpg
Old Apr 20, 2005 | 01:54 PM
Damon's Avatar
Yeah, you NEED those wires to run the ignition module inside the distributor- won't run without them. Cut somewhere in the middle, extend, and reconnect them to their original terminals.
Old Apr 20, 2005 | 10:47 PM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Sorry I diddn't mean to confuse any one. If you just want to relocate your coil cut the wires and lengthen them.
If you want to use an after market coil, just hook both pinks (dist. and harnes) and both whites (dist. and harnes) to the new coil.
Old Apr 21, 2005 | 09:22 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
Thanks for the replies. Yes looks like i need to go to advance and get me some wire splicing stuff.
But now I'm thinking may as well get a new coil, cause this old one is old and just looks like crap. I read some other posts about coils and people were trashing accel and MSd.
Ive decided since I'm going to be moving things around and buying new stuff, I might as well get something GOOD,
any suggestions?
also on remote mounting, it seems like heat and vibration and water are what kills these things so i'm a bit worried about where and how to mount so it will last.
anybody got a pic or two showing remote mounted coils need ideas?
Old Apr 21, 2005 | 10:57 AM
Damon's Avatar
I'm not sure why anyone would bash Accell or MSD. I've used both of them many times and never had a problem with either. I prefer the MSD, personally.
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
