Sportsman200 heads with self-aligning rockers?
Old Aug 5, 2001 | 09:13 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
I'm going to be using a set of Sprotsman200 heads and was planning to use roller tip self-aligning rockers any problems with it?
The sales guy at Scoggin Dickey thought the Sportsmans used an alignment tab screwed to the rocker stud, yet the push rod holes are about 1/2" wide and should work with the self-aligning rockers I have. I have no rocker studs yet, much less any alignment tabs.
Anyone else with any knowledge with using these heads and self-aligning rockers?
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
79 TA 6.6l - all original stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, 12.40 @ 108 w/1.79 60'
95 Trans Am Conv.- LT1
Old Aug 6, 2001 | 08:31 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
When I had my Sportsmans 200 heads I used the guide plates that came with the heads & regular roller rockers by crane. No problems there.
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 lph walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
New mods as of 6/10/01:
383sb engine
Comp Cam Xteme XR264hr-12
smog pump by-pass
Old Aug 6, 2001 | 01:46 PM
2QUIK6's Avatar
Has anyone used these heads without the guide plates and used self-aligning rockers?
Old Aug 6, 2001 | 02:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That setup should work fine on those heads the same as on any other heads.
ICON Motorsports
Magman
Sep 12, 2015 10:43 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
