help with removing smog pump
Old Apr 20, 2005 | 11:32 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i stripped the upper bolt holding it in,, i got the lower one out. i hate these star bolts they suck ***. but anyways, whats the best way to get this bish out? thanks!
Old Apr 21, 2005 | 12:16 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Re: help with removing smog pump
Originally posted by TraviZ
bish out? thanks!
Sounds like something my old lady would say when she can't say nothing else. Stoooopid bish!
Old Apr 21, 2005 | 12:40 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks for the laugh ! but its not helping lol
Old Apr 21, 2005 | 01:42 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
PB blaster? Hammer? Vice grips? Hacksaw?
Old Apr 21, 2005 | 01:44 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i did pb blast it before giving up for the night im gonna go out in the morning and try.. then ill try with pliars, if that doesnt work, ill get a T 45 or T50 bit and try to hammer that in their to turn it. if that doesnt work im selling the car.
Old Apr 21, 2005 | 03:13 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
What size bit were you using? I thought those were t47's anyways?
Grab a torch and heat it a bit?
Old Apr 21, 2005 | 05:12 AM
My1986IROC-Z's Avatar
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
Use your handy dremel with a cutting round on it. I have saved my *** working on my car with the dremel and a cutting bit. Good luck
Old Apr 21, 2005 | 10:12 AM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
If you have enough room on and around the head the bolt-outs available from Craftsman are awesome. Paid for themselves instantly!!
Old Apr 21, 2005 | 10:22 AM
KenV's Avatar
Car: A few
Engine: All Eights
Transmission: All kinds
Word of caution:
I had to remove a few of those bolts after noticing that the driver side serp bracket was slightly out of whack. When I checked the bolts, I found that one bolt was headless. I decided to replace all the bolts with grade 8s, and grabbed an ez-out for the job. I'm glad I had goggles on when I went to drill the pilots. On the very fist bolt, the remainder of the shank burst into a cloud of metal particles. After spitting out some powdered metal I soldiered on, and the other two bolts that had their heads go AWOL popped in similar fashion.
Cliff's Notes: Wear goggles if you drill on those bolts at all.
K
RazorN8
Jan 7, 2022 11:44 AM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
