Strange dash noise
Old Apr 22, 2005 | 03:52 AM
GravyGut's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: Auto w/ overdrive
Strange dash noise
Just lately I started hearing a chirping comeing from what seems like the driver side dash. Only when moveing. It sounds like there is a hyper, pissed off hamster squeeking all kinds of obsenities in there. Not real loud, just loud enough to bother me. The chirping speeds as the car moves faster.
Any wild Ideas on this one?
Old Apr 22, 2005 | 05:56 AM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
I've found that smacking the offending interior trim piece will sometimes shut it up. Try having a helper ride with you, and have them press and lift and stuff on various locations and panels for the dash, to see if the noise changes or gets worse or goes away, that will help isolate the source of the noise. My radio cover plate on the GTA does some squeaking, it's loose. Fixing the actual problem is a whole different can of worms, though, it could be as simple as a loose dash screw. Does the noise happen if you're in reverse? It could be airflow hitting something....
Or just maybe you really have a live hamster running around in your vents....
Old Apr 23, 2005 | 06:02 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Sounds like the speedo cable or speedometer is about to crap out
Old Apr 23, 2005 | 06:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Like BRobinson said. You might consider a search. Cleaning and lubing the speedo cable has been discussed fairly often.
JamesC
MantyZ28
Nov 8, 2015 06:54 PM
BWilcox
Sep 20, 2015 12:19 PM
gta_knight
Sep 17, 2015 03:48 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Randomtask2
Sep 7, 2015 05:06 PM
