What is this thing called?
Old Apr 22, 2005 | 07:36 AM
charliemccraney's Avatar
Car: 1988 Firebird Formula
Engine: 305 (LO3)
Transmission: 5 spd manual
I am replacing the vacuum lines. What is this called and is it easy to find?
Old Apr 22, 2005 | 07:38 AM
Engine: 305 (LO3)
I was also wondering where this harness should clip to. It goes to the fan. The Engine is an '88 LO3 if that matters.
Old Apr 22, 2005 | 07:54 AM
ede's Avatar
ede
i think the first pic is a filter for the harness any place it'll fit, unused hole, look in the prackets
Old Apr 22, 2005 | 08:05 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
The valve looks like the htr, a/c, and cruise check valve. Should have three vacuum lines into it. GM part# 14056648.
Old Apr 22, 2005 | 08:19 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
You can also find those check valves in the 'Help!' section of most autoparts stores.
Old Apr 22, 2005 | 10:02 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Yup its a check valve. About 3 bucks at an autoparts store. Other pic is the fan wiring clip. It attaches to a hole on the fan shroud.
Old Apr 26, 2005 | 07:58 AM
Engine: 305 (LO3)
Thanks! I got the check valve and finished the vac lines.
I don't see any place within the range of the fan harness that the clip could mount to. There just isn't enough slack. I guess I'll just zip tie it to the shroud.
redmaroz
Apr 25, 2017 07:14 AM
LittleFranks
Aug 20, 2015 03:55 PM
Bob88GTA
Aug 18, 2015 03:31 PM
86White_T/A305
Aug 17, 2015 12:16 AM
