yanking 305 tpi??
Old Aug 7, 2001 | 02:39 PM
brettd's Avatar
yanking 305 tpi??
I am pulling out the 305 tpi and i am swapping in a 350. What kind of manual do you guys reccomend chilton, gm?? and how long do you think it would take to take out the 305? and are there any special tools i need or tricks i should know about pulling the motor out of my trans am
brett
86 trans am
brettd@broadcast.net
Old Aug 7, 2001 | 02:58 PM
RW91B4C's Avatar
Where you at in Houston Brett? I will be yankin out my 305 as soon as I finish the 383
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
Old Aug 7, 2001 | 03:06 PM
brettd's Avatar
over near 610 and i-45 = ) but right now the car is in deer park beltway 8 and 225 what is your email and do you live close??
Old Aug 7, 2001 | 03:42 PM
maksik7's Avatar
If you just want to yank it out shouldn't take more then 2 days. But what you want to do is label EVERY SINGLE little hose (especially the dozens of smog hoses) or you'll never remember where they go. From what I learned from pulling my LB9 all you have to do is take off the distributor and the motor will come right out. It's not necessary to take off the whole intake.
Remeber to drain the coolant (and from the block itself) and the oil and you should be fine.
-Max
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
