Help me line up top dead center
Old Apr 23, 2005 | 03:34 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Ok, i am to the point on my cam swap where i am putting the new timing set back on and trying to get it in time. Now i always thought that to set the timing right it was dot to dot (cam dot @ 6 o clock and crank at 12 o clock) but i have done some research and found that it both 12 o clock. I have done a search but it seems like ive found both answers, now keep in mind the heads are off also,THanks
Old Apr 23, 2005 | 03:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Do it either way, it makes no difference.
Old Apr 23, 2005 | 03:49 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Ok, that explains alot. Thanks
Old Apr 23, 2005 | 07:23 PM
ede's Avatar
ede
it makes alot of differance reguardless of what you might read on the internet. dot to dot is best for installing them and lining them up. both dots up (after installing dot to dot) will be firing on #1. dot to dot would be firing on #6
Old Apr 23, 2005 | 08:17 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
But whether its number 1 or number 6 cylinder, its still in time right?
Old Apr 23, 2005 | 10:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Dot to dot is the easiest because it's easier to see them together. Once the dots are lined up, make sure the distributor is dropped in with the rotor pointing to where you want the #1 plug wire to be.
Old Apr 23, 2005 | 10:30 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Wouldn't you want to have it dot to dot when installing the cam? Then when that is done right, turn it over till both dots at 12:00 for the dist. install? Both at 12 is #1 fireing position. Cam at 12 and crank at 6 is # 6 fireing position.
1992 Trans Am
May 10, 2023 07:19 PM
two-if-by-sea
Exterior Parts for Sale
Sep 13, 2015 06:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
sonu1975
Aug 11, 2015 08:38 AM
