How much HP!
How much HP!
Will I see With this set up?
87 LG4...
Street Dominator Highrise Intake,
Headman Headers-gutted cat-80 series flowmaster,
Open element breather.
MSD coil,dist,8mm wires.
mild cam and lifter set.
Trash all emission crap!
Will I at least see the 14 second range? Or do i need NOS(75 Hp shot) to get there??
Thanks!
Jordan...
87 LG4...
Thanks!
Jordan...
Car: 4
Engine: 6
Transmission: 5
There's not enough information to make an informed guess.
What heads? what cam? The ignition stuff doesn't matter. The open element will slow you down comapred to a L69 breather. If you gutted the LG4 cat and left it there, and all your exhaust is still hooked up to it, then at best you've got a fire hose that necks down to a drinking straw.
ICON Motorsports
[This message has been edited by RB83L69 (edited August 06, 2001).]
ICON Motorsports
Car: 4
Engine: 6
Transmission: 5
What heads? What sort of exhaust? Stock covers alot of ground, from 1.74" valve 267 heads to 2.02 valve LT-1 heads and a whole lot in between.... Custom exhaust is meaningless, what size pipes are they, is the OE cat still there with its 2¼" bottleneck, etc.... Also, if this is a 87 LG4, you're a little bit lucky because you have flat-top pistons so your CR is up around 9¼-9½. If you have dished pistons, take about 4-5% off the estimates.
If they're the swirl port 305 heads like what come on TBI motors, you'll be hard pressed to get 250 HP out of the motor no matter what else you do. If they're "better" 305 heads like 416s, you might get as much as 285 HP or so out of it if it's got a maxed out exhaust and a really good (not ncessarily "big") port job on the heads. I can't think of the casting # for the better heads for that year. TPI cars and Monte Carlo SSs had those, I don't know for sure what the LG4s came with.
A stock L69 is very close to 14s, if not already there. You should make it if the motor runs right.
ICON Motorsports
ICON Motorsports
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Desktop Dyno 2000 says you have around 275hp with that setup, and this will be pretty accurate, too
1986 Camaro Sports Coupe
T-tops, power hatch, rear defrost, third brake light
LG4 305 V8, Hooker Shorty headers, Edelbrock Performer intake,
"Damonized" Q-Jet 4bbl, K&N filter
Crane ignition kit, TH700R4 transmission and Derale cooler
Air conditioning, pw, pl, pb, ps, tilt wheel
Kenwood cassette, Pioneer 6x4 component front speakers
Rockford Fosgate 6x9 Punch rear speakers
Aluminum slots and Goodyear 225x60R15 Eagle HP tires
Thank you Sitting Bull!! You're a good man!!
I think 275hp and a well running engine with a 75hp shot of NOS will be a very nice setup.
Hey, for an LG4,you can't complain.
I went to GMGoodwrench today and priced the 350HO deluxe crate engine. Only $7,134.00 after Taxes and not installed.Not bad eh!
I think I'll dump 2 grand into the 305 and have similar results thanks!!
Jordan
[This message has been edited by MR. JORDAN (edited August 07, 2001).]
I think I'll dump 2 grand into the 305 and have similar results thanks!!Jordan
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<font face="Verdana, Arial" size="2">Originally posted by MR. JORDAN:
I went to GMGoodwrench today and priced the 350HO deluxe crate engine. Only $7,134.00 after Taxes and not installed.</font>
Yeah. I priced the ZZ4 aswell and it came to 6,300.00 Before taxes. Way too much cash to spend on an engine IMHO. I think building my own is the way for me. I'll learn a lot more too. I can buy a used SB here for a fraction of the price of a ZZ4. I'll just make sure to do a compression test and swap over all the bolt on's..
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Ouch. I priced out a ZZ502 (502/502) longblock at GM for $8600
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
