Have problem w/ belt being too small. HELP!
Old Aug 5, 2001 | 09:15 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I just removed the smog equipment and I went and bought a belt but the belt was too small. I got a 96.8" belt and it is almost 2" too short. What should I do. I didnt but the Dayco belt but the length was the same. What size do you guys think I need. Should I look for the Dayco belt or go with the size that the 968k6 converts too or what? Please help I am trying to get this thing back together. Thanks in advance for the help.
Old Aug 5, 2001 | 10:44 PM
Nordbert's Avatar
I recommend NAPA Auto Parts if there is one near you. I had a similar problem with a
Cavalier, and they had a serpentine belt that
was a perfect fit.
Old Aug 5, 2001 | 10:51 PM
rezinn's Avatar
Are you having a person pull out the tensioner when you try to put it on? That can take up the slack of several inches, or cause an innacurate measurement if not pulled out a little.
Old Aug 6, 2001 | 02:19 AM
Omar's Avatar
Are you sure you are routing it correctly with the smog pump removed?
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Aug 6, 2001 | 02:14 PM
I EAT T/A's Avatar
Car: '87 Camaro
Axle/Gears: 10 bolt, 3.23 posi.
The belt is for my car, I couln't remember my password last night.
We bought a 96 5/8" belt from NAPA and it doesn't fit, even after pulling the tensioner back.
Yes the smog is now deleted, WTF do I do now??
Brett
'91 Z28 Black
125K,L98,3.23,4L60.
Panhard,LCAs.
MN F-Body
Brett's House
Old Aug 6, 2001 | 04:16 PM
rezinn's Avatar
How much too small is it? I went through this yesterday, 3 trips to the auto parts store but it finally worked. Just keep trying
Old Aug 7, 2001 | 03:20 PM
I EAT T/A's Avatar
Car: '87 Camaro
Well, the belt size at NAPA that worked was actually 97 1/4" long, but that is the size that came up under 968k6 part number.
At least she runs again...
Brett
'91 Z28 Black
125K,L98,3.23,4L60.
Panhard,LCAs.
MN F-Body
Brett's House
Old Aug 7, 2001 | 07:43 PM
Guest
Guest
Posts: n/a
968k6 is 96.8" long and 6 ribs wide.
Serpentines are easy to get belt sizes if you have a helper, you just need a long string and just wrap it around the pulleys like you wanna route the belt, then have your helper hold the tensioner in the right spot, and you have your length.
Corry
Jun 18, 2001 03:49 PM
custman87T/A
May 31, 2001 06:49 AM
CAMARO-90-RS
Dec 18, 2000 01:27 AM
