Which style of retrofit roller lifters?
Old Aug 6, 2001 | 10:03 PM
MikeS's Avatar
There are two different kinds of aftermarket retrofit roller lifters. Some have vertical bars linking lifters to one another, and others have what looks like bars laying horizontally with some sort of spring in the lifters. Some companies make one kind, some make the other, and some make both. Any ideas as to which style is preferable?
[This message has been edited by MikeS (edited August 08, 2001).]
Old Aug 8, 2001 | 09:34 AM
MikeS's Avatar
Anybody? I feel like I'm being shunned here. Or maybe I stumped you all? I guess they are all good enough for most use, so it would be ok to go with whatever was cheaper.
Old Aug 8, 2001 | 10:15 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
AFAIK for a street motor it doesn't make a whole lot of difference. Most of the ones I've used have been the vertical bar type. I've never had a problem with either, and haven't run into a situation where either design was clearly superior.
The Lunati ones with the horiz bars are designed such that the link bar rests against the block before the lifter goes all the way in, and the spring has to be compressed to push the lifter all the way down to where it contacts the cam; then if you remove the rocker and pushrod, the spring pushes the lifter back up far enough to slide the cam out. That way you don't have to pull the intake to swap the cam. Of course if you use a Hydra-Rev or equivalent then that doesn't work.
ICON Motorsports
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
codeysabatini
Nov 10, 2015 04:07 PM
anesthes
Sep 18, 2015 12:34 PM
RyanJB
Sep 14, 2015 03:39 PM
dimented24x7
Sep 6, 2015 03:51 PM
