oily spark plug on threads
Old Apr 25, 2005 | 01:14 PM
d10pins's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L
Axle/Gears: 3.70
i have an 1989 camaro with trick flow heads, and im getting oil all over the threads. what will cause this. thanks
Old Apr 25, 2005 | 03:02 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Is the motor consuming oil? Blue smoke at idle or WOT? Puff of smoke at startup? Could be a lot of things... Just need to get a little more info...
Old Apr 25, 2005 | 03:43 PM
d10pins's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L
Axle/Gears: 3.70
NO SMOKE AT ALL. IT IS HARD TO START A LITTLE AFTER IT WARMS UP THOUGH/
Old Apr 25, 2005 | 05:34 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Re: oily spark plug on threads
similar problem, but with stock heads, fresh rebuild, less than 200 mi on it. used to blow a puff of smoke on start-up after the rebuild, doesn't do it now, but is consuming oil... level is down about 1/2 qt. (rebuild is on the '91, btw) i have oil on the threads and look a little coked up - not burning "clean". supposedly only problem i had was lean at idle, but doesn't look that way to me.
not jumping on your thread, just wanting to find out the same info...
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
