valve springs
Old Apr 25, 2005 | 06:11 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
valve springs
would i see any improvement in power by installing LT4 valve springs on my vortec heads, but having a cam that has a .460 lift?? i have some laying around and i am wondering if it would be worth it to use them.
Old Apr 25, 2005 | 06:58 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I believe they're 1.32" OD, so the spring pockets on the Vortecs would need to be enlarged.
I could be thinking of the LT4 Hot Cam springs though.
Measure them. If they're much larger than 1.25" then they won't fit.
Old Apr 25, 2005 | 10:19 PM
7plagues's Avatar
they are larger, and i would need to get the pockets enlarged. but im just wondering if i would get an increase in power or not, just from them.
Old Apr 25, 2005 | 10:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not likely, unless your stock springs are so worn out that the valves are floating.
Old Apr 26, 2005 | 12:21 AM
7plagues's Avatar
ok i was just wondering cause their just laying around now...the lt4 springs that is
Old Apr 26, 2005 | 11:53 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
They're bound to be better than stock Vortec springs. As Apeiron hints, anything over 5000 RPMs, you'll see a "power increase" since the valves shouldn't be floating.
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
