335 stroker
Car: 1992 Camaro RS
Engine: 305 TBI undergoing a 355 transplant
335 stroker
Has anyone done a 335 stroker and what kind of gains have you seen from it, also is it worth the money if you upgrade the cam, heads and switch to a good intake and carb? Thanks
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Try searching for 334 also since that's what a 305 block bored out .030" with a 3.75" stroke calculates to.
Car: 1992 Camaro RS
So far from what I can find is a bunch people saying it aint worth the time and money. All I'm trying to find are some people who have done and what kind of results they got.
Out of all the people you saw that say it's not worth the time and money, I think there's one guy that actually did it. I can't think of his name right now but if you keep reading the results (I know.... there are a lot and they're long) you'll find him.
BTW, There's a reason there are so many people that say it ain't worth the time and money.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Originally posted by Red Devil
That's easy, the results are always 'not as good as a 383 would have been'.
Car: 1992 Camaro RS
I am looking for some one who can give me numbers like HP and torque. Then I will see if it's worth my time and money to build. If not then I can see about building something different.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Well **** you can build anything to produce as much hp and tq as you desire. All it takes is money!
Car: 82 Z28
Transmission: TH350
You can build a 350 for much cheaper than a 305 stroker. You can build a 383 for about the same price.
Why would you want a smaller less powerful engine?
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Originally posted by Apeiron
You forgot "for the same price- or less" at the end of that.
Engine: 383 Carb
Transmission: 4L60
As an example, <a href=http://www.enginekits.com>enginekits.com</a> has a complete 335 kit for $599. Their 383 kit is only $489. A used 350 block is less than the $110 difference in price.
(I'm not endorsing the company, their parts, or their prices, just using them as an example.)
Car: 1985 Z28
Engine: 383
Axle/Gears: 10 bolt/3.73
I was thinking about building a 305/335 stroker, but after talking to everybody on this site, I decided to get a 406 instead. Thanks again to everybody who talked me out of my stupidity as this was a much better choice.
The guy that has the 335 is named Tunedport 335. He posts on here a good bit so it ought to be pretty easy to find him.
Car: 1992 Camaro RS
Thanks for your opinions. I am going to go bigger or not at all. Unfortunately, it is going to be after summer before I can do anything, but it will be done.
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
People don't even try with a 305 because of the 305 vs 350 backlash and the fact that prices are cheaper for the 350. Not saying that the 305 is a bad block to start with, but no one wants to give it a chance and put the money into it, because you could get more with a 350.
A ported stock base and aftermarket runners would be a good match for a 305, imho.
Car: 1992 Camaro RS
The trouble you're having finding success stories w/ the 335 should be telling you something...
Car: 86 Camaro Z28
Engine: 5.3 LM7
Transmission: TH400
About 4 years ago a friend of mine used to have an 89 iroc 335 stroker with GMPP Corvette H.O. heads and a decent cam with all the other bolt ons 3.73 gears and a tremec tko 5 spd, he was running 13.1-13.3 He did it just to be different.
Car: 1985 Z28
Engine: 383
Yeah...I see now. I was thinking about it because not alot of people that I know of have tried to build a 305. So more or less it was to try and see what its potential is. Thanks for all the opinions. Guess I'll spend my money on a different motor.
Chevykid810
Sep 28, 2015 12:57 PM
