305 Tpi Fuel Injectors.....
Old Aug 9, 2001 | 10:39 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
My mechanic says I have a few bad injectors, new ones are far too expensive i'm looking for used ones. Will any OEM injector from any year LB9 fit my 1990 or did they change something to accomidate the SD setup?Are there any other GM cars that used the same injectors as my LB9?
1990 Iroc convertible,305 tpi,Black with black leather interior,lowered,Taylor 8mm wires,K&N's
Old Aug 9, 2001 | 11:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yeah, and they are all the same Multec crap you've got that is broken. I went through the same thing on my wife's 5.0 Cadillac not too long ago.
Get a set out of Denso ones from a Mustang, they're a dime a dozen, and send them to www.cruzinperformance.com for a rebuild. You won't believe you're driving the same car. Make sure you use the right O-rings when you put them back in, tell Rich what you're putting them in and he should be able to supply the correct ones. I paid $35 for the set I got, and $80 to Rich, and literally was blown away by how much better the car ran afterwards.
ICON Motorsports
Brcharrelson
Aug 26, 2015 07:47 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
