surging problem, how do i pinpoint vacuum leak?
Old Apr 27, 2005 | 05:58 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
my car surges bad when the rpms drop under 850 or so then dies. i've got the rpm set at 900 in gear and 1150 in park and it doesnt do it but im pretty sure its a vacuum leak causing it. someone made a post advising to spray carb cleaner around the engine to find a leak, sure enough it went nuts and just about died when i sprayed around the heads, but thats still pretty general. how do i go about pinpointing the leak?
Old Apr 27, 2005 | 10:44 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Propane. Esp. if you have the general area down.
Old Apr 27, 2005 | 10:45 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Kidrcth disclaimer- do not light the propane torch before use for this particular application...
Old Apr 28, 2005 | 01:12 AM
1meanGTA's Avatar
will it be visible or is it just a more accurate way of finding where is making it choke?
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
perZ
Aug 21, 2015 05:51 PM
bamaboy0323
Aug 15, 2015 07:20 AM
