Help! can't get alternator pulley off!
Old Aug 9, 2001 | 08:03 PM
Todd 92 Z's Avatar
I'm rebuilding my alternator and I can't get the alternator pulley off because the torx head bolt is stripped! Any ideas on how to get it off? Thanks in advance!
Old Aug 9, 2001 | 08:55 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
You could use a chisel and hammer or if you know someone with an impact. I've used the chisel method and works fine but tears up the nut a bit.
92 RS, 350, Street & Performance MPFI, TFS heads, Stock crank and rods, Fordged flat tops,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Old Aug 9, 2001 | 11:56 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Impact.
Hold the blades with a rag around your hand and hit it with the impact gun.
Works every time.
They aren't usually that tight.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
