need help finding wire
Old Apr 27, 2005 | 07:54 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
im trying to find the wire that goes to my oil pressure sending unit. i know it had a round rubber cover on it but i can't seem to find it. does anyone have any idea were it could be. the car was with out a motor for almost a year. i know its going to be difficult, but if anyone has any suggestions please post them.thanks
Old Apr 28, 2005 | 10:21 AM
Damon's Avatar
The main oil pressure sender screws into the block just above the oil filter. The 2-wire connector that plugs onto it (round, as you say) should be poking out of the wiring harness somewhere not too far from there.
Some (not all) 3rd gens have another sender up on top of the engine, at the back, just to the driver's side of the distributor. I believe that one is a single-wire sender, just like in Chevys from the days of old.
Old Apr 28, 2005 | 04:48 PM
Car: 84 camaro Z28
Engine: 434sbc
i have the one sender on top of the motor all the way in the back. i know the wire is there i just can't find it. its probably right under my nose.
Old Apr 28, 2005 | 06:20 PM
kevinc's Avatar
Car: 1982 Z28
It's in the main harness that comes off C100...big electrical connector on the firewall drivers side near the brake booster.
Start at the connector and trace your way along the split of the plastic loom, you'll find it.
Old Apr 29, 2005 | 12:50 PM
Car: 84 camaro Z28
Engine: 434sbc
you wouldn't happen to know what color it is would you
Old Apr 29, 2005 | 01:11 PM
kevinc's Avatar
Car: 1982 Z28
Should be tan. Not to be confused w/ the tan one with a white stripe, just plain tan.
Old Apr 29, 2005 | 05:49 PM
Car: 84 camaro Z28
Engine: 434sbc
thanks alot
Old Apr 30, 2005 | 05:39 PM
Car: 84 camaro Z28
Engine: 434sbc
just wanted to let you know that i found the wire. thanks alot
Old Apr 30, 2005 | 05:47 PM
kevinc's Avatar
Car: 1982 Z28
Cool beans, get that thing running! I'm in Morris Plains and it's getting boring down here.
Old May 1, 2005 | 07:00 AM
Car: 84 camaro Z28
Engine: 434sbc
it would be running this weekend put the fuel log for the carb is on back order until *** knows when from jegs. i tried every performance place by me and noone has it. looks like its going to have to wait.
Old May 1, 2005 | 07:37 AM
kevinc's Avatar
Car: 1982 Z28
If you haven't called Bruce's Speed Shop yet, give him a shout. He's in Rockaway and has all things carb. A little bit of a road trip for you but worth it.
Old May 1, 2005 | 10:05 AM
Car: 84 camaro Z28
Engine: 434sbc
i never even thought to try him. ill call jegs tomorrow and see how long its going to be.
Old May 1, 2005 | 11:26 AM
kevinc's Avatar
Car: 1982 Z28
Bruce keeps a good inventory of both carb and FI stuff, and usually by the time you add Jegs/Summit $8.95 handling fee his prices are competitive.
He also has a dyno, wideband O2, and Holley jet kit. I've seen him doing carb tuning and jetting on the dyno and it's a very clean process.
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
apie2546
Aug 8, 2015 07:12 AM
