Can I install this intake on my Tpi
Old Aug 9, 2001 | 12:20 PM
jobryan26's Avatar
I was just browsing on ebay and saw this pic of a 85 iroc and wanted to know if I could install one of these intakes on my 87 t/a.
Trans Am:
(Engine)305 TPI
180 Degree Thermostat
JET Fan Switch
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)Full Kenwood Excelon System
See my Ride:
https://www.thirdgen.org/rides/index...ew&rideid=1324
Member at kyfbodies.org
Old Aug 9, 2001 | 01:01 PM
ATOMonkey's Avatar
What part of the man do you want? Top or Bottom? I don't know much about TPI, but if that is an '85 then the manifold bolt pattern for the bottom half is different on your '87. I'm not sure, but the top would probably fit on your base.
Old Aug 9, 2001 | 01:14 PM
GeneralGrant's Avatar
Yea im curious as well, if so then i could install the homemade ram air induction. Im talking about the Y plastic witht the maf, currently mine is goes off to the left to where the airfilter is...
Old Aug 9, 2001 | 01:29 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
I don't think it possible. Some local thirdgenners were discussing this and the hood of the Firebird is so different than the Camaro that it would not close with the TPI "dual intake snorkel". I do know that Camaros can use the Firebirds intake (Which GM converted the Chevy's to with the LT1, but to the left hand side), and could possibly flow better. Or at least aftermarket version can.
George P. Lara
1984 Z28
2001 SS #0391
SCCA, SCFB, SC3GFB
Old Aug 10, 2001 | 12:00 AM
jobryan26's Avatar
Yep the y-part of the intake that the air filters are in. Anyone tried it know for sure?
Trans Am:
(Engine)305 TPI
JET Fan Switch
TB Bypass
Accel Super Coil
See my Ride:
Old Aug 10, 2001 | 12:26 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Tried it & it does not work. The different bracing of the hoods over the radiator support keeps it from working on a f'bird.
Old Aug 10, 2001 | 10:43 AM
jobryan26's Avatar
<font face="Verdana, Arial" size="2">Originally posted by deadbird:
Tried it & it does not work. The different bracing of the hoods over the radiator support keeps it from working on a f'bird.</font>
Thank You Sir
Trans Am:
(Engine)305 TPI
JET Fan Switch
TB Bypass
Accel Super Coil
See my Ride:
Old Aug 10, 2001 | 12:29 PM
Drakar's Avatar
Supposedly, I read it somewhere on this board but Im not sure, but the bellow that the firebird uses is supposed to be worse which is why we have a 5 horse less then the camaro, atleast with the 350's. Not sure if this is true or if it is some other factory we lost 5hp but oh well.
1989 GTA 350 TPI
Stock:
- T-tops
- Dual cats
- 9-Bolt 7.75" Rearend
- 3.27 gears
Mods:
- Dynomax Super Turbo Muffler
1992 RS 305 TBI - Sold
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
