accel plug wires and edel. header conflict need some ideas!!
Old Aug 9, 2001 | 06:25 PM
camaroguy99's Avatar
alright well I got my headers on and I replaced the wires with accel 8.8 300+ wires. now all the pass. side wires either contact or run very close to the headers, and on the #7 cylinder the strait boot is resting against the primary tube comming off that same cylinder. Can someone please give me ideas on how to route these wires so they don't burn up and short? thanks guys.
On a brighter note. The car finally started after my 305 TBI/350 TPI engine swap. I just wanted to thank everyone so far for their help, it never would have gotten this far without you guys. thanks again.
Jim
Old Aug 9, 2001 | 07:04 PM
ede's Avatar
ede
i'd buy some good wrap for the wires. cost you about 50 dollars or so to protect the wires.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Aug 9, 2001 | 07:30 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Wraps would be a good idea, I have burnt up 2 wires already, I found that using zip ties help a bit.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
Old Aug 9, 2001 | 07:31 PM
CAMARO82's Avatar
Try putting shorty sparkplugs in, They sell them at Autozone or Checker... Laters Greg
I think they call them something like Header Sparkplugs
Old Aug 9, 2001 | 09:01 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
Problally the best idea would be to use 90 deg. boots. Thats what I use with my Edelbrocks. They will get very hot, I had my share of burnt wires. So far the 90 deg. ones are working the best.
92 RS, 350, Street & Performance MPFI, TFS heads, Stock crank and rods, Fordged flat tops,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Old Aug 9, 2001 | 09:08 PM
boogada186's Avatar
I use the accel Header Spark Plugs for my car and they are great. Also I would buy the plug wire wrap and consider wrapping your headers in Heat Wrap. I wrapped my headers in the stuff and it is great. It protects my wires and is also supposed to help performance, or so they say.
Old Aug 10, 2001 | 01:27 PM
ecelbrock says that header wrap will void the warrenty so I don't want to do that, I didn't know accel made header wires I thoought they only had that one set. I'll check that out too. thanks.
Jim
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Derick15
Sep 17, 2016 05:28 PM
evilstuie
Feb 28, 2016 03:33 PM
