Urgent fuel rail question.
Old Aug 10, 2001 | 10:00 PM
JETHROIROC's Avatar
I'm in the process of taking the fuel rail completely apart to replace all the o-rings
and I was wondering if the joint where the fuel inlet tube goes into the rail is seperable. It doesn't seem to want to come out easily, and the service manual doesn't show it coming out in the exploded view, but I have one large o-ring in the kit that looks like it belongs there. Thoughts/suggestions are welcome. Thanks for your time.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats, no cats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Aug 10, 2001 | 10:53 PM
Guest
Guest
Posts: n/a
Nope, that does not come out.... well not in any normal situation it doesnt. That o-ring has to belong to somewhere else.
Old Aug 10, 2001 | 11:13 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Skinny O-ring? If so, there should be two of similar (but not the same) size for the fuel input and return lines on the intake.
Old Aug 11, 2001 | 06:09 AM
JETHROIROC's Avatar
Thanks guys. I reckon I'll stop yanking on it now .
Old Aug 11, 2001 | 09:26 AM
Vader's Avatar
Jethro,
Like I posted on the TPI board, the larger, small cross-section 'O' ring is probably for the cold start injector fitting at the opposite corner of the fuel rail. If you have a later TPI without the cold start valve, you now have a spare rubber band.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Andrew6.688
Dec 13, 2015 10:59 AM
stalkier
Dec 6, 2015 11:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
