Car was running rich now wont start at all
Old Apr 30, 2005 | 07:06 PM
IonNight's Avatar
Car: 1986 Iroc Z
Engine: Truck 305 /Bored .30 Flat Pistons/ Crane Cam
Transmission: Corvette 700R4
My camaro was running rich because the timing is off....
I drove the car home from the mechanic shop cuz he couldnt pass it and parked it.
Replaced the heater core the next day and now the car wont start.
The battery is fine and the lights work;the fuel pump kicks on... I'm not sure about the starter but car has been starting fine for days.
Old Apr 30, 2005 | 07:17 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Induction system would be a handy thing to mention if you really want help. Carb,TBI,TPI and DFI can lead to different answers.
Heater core has nothing to do with not starting. Someone changing the heater core might have knocked a electrical connecton or vacuum line lose. Give it a good eyeballing over to see if all looks right.
Old May 1, 2005 | 07:56 AM
IonNight's Avatar
Car: 1986 Iroc Z
Its a Tpi but I dont know what kinda wire or hose to look for... if I did knock one off it would be near the fire wall
Old May 1, 2005 | 09:17 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally posted by IonNight....if I did knock one off it would be near the fire wall.
You removed the blower motor's external housing underneath the hood to get to that 'one' bolt that lower's the housing located inside of the car, right?
Do you remember a ground being connected on the bolt closest to the distributor, on that external housing? There are quite a few grounds back there, systems ground, engine strap etc...
Double check you're work, and make sure there's nothing hanging loose back there.
You're engine is not starting, but is it at least turning over?
Old May 1, 2005 | 12:42 PM
IonNight's Avatar
Car: 1986 Iroc Z
thank you halfinchwrench and street lethal..
I found the ground to the battery loose so I tightened it and it started right up!
Steven 86IROC-Z
May 24, 2026 04:52 AM
MustangBeater20
Oct 29, 2022 09:20 PM
squiggy2
Aug 9, 2015 09:30 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
