no crank / no click - full power
Old Apr 30, 2005 | 10:22 PM
sp63
Guest
Posts: n/a
njspeeder said touch pos side of batt to some wire on starter with jumper cables.
so ...
blue i couldnt get a jumper cable on
top red = sparked
bottom red = nothing
does this mean bad starter?
bad vats?
bad something else?
how about i have to clamp jumper cables onto pliers and touch them to that blue wire? (might fit that way)
Old Apr 30, 2005 | 10:30 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
From that pic, the starter looks fairly old. I would take the starter off and take it to your local Advance/Autozone and have them test it- can't hurt anything and you don't have to worry about shocking the **** out of yourself
If the starter tests out fine then next thing to check is VATS.
Old Apr 30, 2005 | 11:00 PM
sp63
Guest
Posts: n/a
yea uh. the point of jjumper cabling the pos side of batt to the starter was to bypass vats and test the starter itself..
BRoss99
Aug 10, 2025 05:08 PM
B_Dubya
Aug 26, 2015 05:09 PM
Linson
Aug 21, 2015 02:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
