POTENTIALLY BAD leak on new motor.
Old May 1, 2005 | 11:37 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
I'm pretty freaked out right now... As you all know the SR is a PITA to install. I don't know if I missed something, but I have coolent pooled on the driver side by the middle two lower intake manifold bolts. I'd hate to have to take it apart. I guess it's possible I spilled some, but it doesn't seem likely, given the location. I know the thermostat housing overflowed a tad when i topped it off with coolent at the radiator (after i filled the motor at the thermostat housing). But then again, there is casting in the way form those front manifold bolts and the middle lower manifold bolts. Is there anything on the superam or on a regular base manifold that can cause that?.. I know the manifold bolts are tight and have teflon paste on them. I am pretty sure that i got everything right when i installed everything. The funny thing is the motor hasn't even been satrted, so the water pump couldn't have "pumped" coolent out through a small leak or anything, so I guess unlesss I missed something real big,....it shouldn't be leaking. Any ideas?
Old May 3, 2005 | 08:27 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I would fire it up and run it for awhile to see for sure if it's leaking. I'm guessing you spilled some and it just happen to run down and pool there.
Frozer!!!
Jan 19, 2024 04:55 PM
xxx3man`
Sep 23, 2015 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
mike_c
Aug 27, 2015 04:32 PM
neekolzun
Aug 24, 2015 04:59 PM
