low rpm and stalling ???????
Old Aug 12, 2001 | 10:27 AM
88greyiroc's Avatar
i own a 1988 350 tpi iroc and the car is idling at 500 rpm and every once in a while it will always stall unless i keep the throddle down a ways if i let off the gas the car will stall on me even while i am driven in gear if i let off the gas and i am goin slow enough the car will stall on me i can't figure out what it is and you guys are my last hope there is no codes comin up or nothin so i have no clue but at other times it will iddle and keep itself goin but it idles at about 500rpm which i think is too low and my throttle response is pretty bad too . to get the tires to squeel now i really have to come onto the car.
Old Aug 12, 2001 | 12:15 PM
chiefz28's Avatar
If you have a volt meter tester you could check the TPS(Throttle Postion Sensor)thereis an article in the Tech article on the main page it Setting IAC and TPS.try that for starters.500 is a bit low you should be up around 7 aleast.
1991 1LE Z28 355cu 5SPD (ORIGINALLY 305 BEST E.T. 14.186@99.86mph)NO PASSES ON 355 YET.MINI RAM INTAKE,AFR 190 HEADS,10.23:1cr 24# SVO INJECTORS,BBK 52mmTB,AFPR
FULL ROLLER MOTOR,1.6 rockers MSD 6AL
AUTOMETER A/F GAGUE MARCH PULLEYS,HEDDMEN HEADERS 3IN EXH NO CATS FLOWMASTER,POWER TRAX NO-SLIP LOCKER,3:42 GEARS,LAKEWOOD LOWER CONTROL ARMS HOTCHIKS STRUTTOWER BRACE,COMPETTION ENG.SUBFRAME CONNECTORS
MALLORY TACH W/SHIFT LITE
BLACK, TINTED WINDOWS, TAIL LIGHT COVERS BIG BLOCK COWL INDUCTION HOOD,SHAVED DOOR HANDLES
67RS 327cu 92K ORIG MILES.NEWER GM HEADS HEADERS,650 HOLLEY CARB,CAM, 350 TURBO TRANS W/SHIFT KIT&COOLER 12 BOLT POSI 3.73'S MUTLILEAF SPRINGS
NEW VINYLROOF&CARPET, COWL HOOD,HIDE AWAY HEAD LITES,
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
C409
Sep 1, 2015 03:42 PM
Jake_92RS
Aug 17, 2015 09:42 AM
TreDeClaw
Aug 14, 2015 06:58 PM
