alternator fire/wiring..
Old Aug 12, 2001 | 05:02 PM
rezinn's Avatar
My alternator wiring caught on fire yesterday with the key off.. this is an 87 camaro. There are three wires going into the connector, two black and one red. All three were fried so I need to rewire them, I've traced the wires back to near the smog pump in the wiring harness, but I can't see any difference in the two black wires. Is there any? My positive battery cable also caught on fire.. what could have caused this? Could I have mixed up the two black wires when I extended them(moved the alternator because of serpentine swap)?
I don't want to make another mistake, so please help me so I don't catch my car on fire again Could a bad alternator have caused this? The one I got is not new, it came in a serpentine kit.
Old Aug 12, 2001 | 05:39 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
It does make a difference, if you mix them up, the alternator will not charge.
Also, are you sure they are both black? One should be black and the other should be brown.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Aug 12, 2001 | 07:08 PM
rezinn's Avatar
They are both the same color, black or brown. I've had four people look at it and none could see a difference. Is there any way to tell which is which? I don't really want my car to catch on fire again
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
