Oil pressure gauge dead?
Old Aug 12, 2001 | 07:24 PM
Makaveli's Avatar
hey, my brothers firebird's (89 V6) oil pressure gauge is basically dead, reading zero, but theres still oil pressure obviously because the car still runs.... but the gauge is either dead, or the oil sending unit has a problem... so how can i tell whats wrong, and how do you fix this thing? anyone else have this problem?
Old Aug 12, 2001 | 07:47 PM
Vader's Avatar
Mach,
I'll put a small wager on the sender or its wiring. They are often the cause of this kind of problem. About $25.00 and the problem should be solved. Before you get a new sensor, check the electrical connector at the sensor first to make sure is is plugged in. You can ground the tan wire at the sensor and the gauge should read fuill scale, just to make sure tha gauge is working.
Tell you're brother he's welcome - PEACE!
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
