chugs once and dies.
Old May 2, 2005 | 11:00 PM
duz's Avatar
duz
Car: 82 Firebird
Engine: 5.0
Transmission: 3 speed auto
I just can't figure this damn thing out. I started this a few months ago and i'm finishing up odds and ends. I put a new performer battleship and carb as well as a new dist, computer removal and all that junk. I've started the motor ran fine. did oil change; but the dist. horn was facing the drivers side headlight and the sparkplug wires and other crap were roasting on the exhaust manifold, so i figure new plug wires, i'd pull up the distributor and plunk it down proper, find tdc #1 and retime. now i screwed it good. it just fires a piston and dies. i've fiddled with the timing but to no avail. proper firing order. i am absolutely sire its not 180 out. when it chugs, should i run over to the carb and crank some gas in there or is it something else? iv'e turned that dist at least 20 degrees either way.
Old May 7, 2005 | 10:04 AM
Vader's Avatar
Verify you TDC and compression stroke, then try the distributor position again. It's so easy to get the distributor installed out of position, I can even do it in my sleep.
Old May 7, 2005 | 09:32 PM
sellmanb's Avatar
Car: '86 Berlinetta
Agreed, re-do the distributor, and check the gap on your spark plugs.
Old May 7, 2005 | 09:37 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
may be wrong here,but if the "distributor horn"you are referring to is the vaccum advance canister shouldn't it be facing the passenger side just in front of the hood hinge?sounds like you are 180 out to me.
Eric
Old May 10, 2005 | 12:13 AM
duz's Avatar
duz
Car: 82 Firebird
Engine: 5.0
well it wasn't out 180 but quite a few degrees. the canister now faces the front of the car. it works alright, just looks strange. took it for a test flight up to 80km/h. thats when the gas pedal stuck to the floor . had to shut it off at about 6500rpm. i hope that doesn't hurt things.
Gunner242
Dec 25, 2015 04:49 PM
RedLeader289
Sep 23, 2015 06:50 AM
GTAman
Sep 21, 2015 09:57 AM
EFR2000
Aug 18, 2015 08:54 PM
Dan87IROC-Z
Mar 12, 2001 12:25 PM
