Cold Idle stall....
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Cold Idle stall....
Hi, everyone
I have a 92 5.7 TPI engine, it starts instantly when cold , though after about 30 seconds or so it will, start to load up with fuel, sputter then finally die, it will only restart after i hold my foot on the gas to keep it going after this excess fuel clears out it idles perfectly, hot starts are perfect as well, any ideas?? BTW there are no codes, and watching a Diacom scan of the engine idling show nothing, any direction would be helpful , thanks .....GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Thanks Vader,
The fuel pressure is at 50 PSI vac line off, or 43 PSI on and running, I had some fuel removed "in the prom" at idle and its MUCH better now, thanks. GTA........
