Starter probs! :(
Old Aug 12, 2001 | 05:26 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
Starter probs! :(
ok, my original starter in my 85 cooked, so I put in my newly rebuilt one, but the rebuilt one just 'clicks'. the solinoid pushes the gear out, but it wont spin. that was the same exact prob I had with the original!
I have the starter shimmed and it is definatly far enough away that it isn't binding on the flywheel. so what the heck is going on? how can I test the starter on the bench to get it to spin?
Old Aug 12, 2001 | 05:37 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Alot of times when it "clicks" its from a discharged battery. Are you sure your battery is OK?
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Aug 12, 2001 | 06:02 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
ok an update, the gear for some reason gets stuck on the flywheel! so I guess it does bind up. but why!? the starter is no where near being too close, I've tryed changing the angle, shimming closer and farther. it just clicks and gets stuck on the flywheel.
perhaps the starter just isn't turning? how can I test the starter on the bench?
Old Aug 12, 2001 | 07:14 PM
rezinn's Avatar
You have to send 12 volts into the solenoid and ground it somewhere.. it will give you a good kick if it isn't broken. I would assume the starter is good if neither it or the old one worked. Hows it getting "stuck?"
Old Aug 12, 2001 | 07:38 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
ok thats what I did, I tripped the solinoid but the gear just clicks over and doesn't turn. neither of them spin...
I think it gets 'stuck' because the gear jsut moves out but does not keep spinning so it jsut sits there. either that or the starter is not sitting perfectly parellel with the flywheel, and it gets bound up. but if i hold the key on it does not sound like the starter is trying to turn.
I guess I will try cleaning the armatures.
argh!
Old Aug 12, 2001 | 10:46 PM
Nordbert's Avatar
It sounds like the brushes are not seated on
the armature. Turn the armature with the
starter drive a few turns, and try bench test
again. Hint: Have the sales person bench test
the starter BEFORE you buy it.
Old Aug 13, 2001 | 11:36 AM
1990 IROCZ's Avatar
I'm having the same problem with my car, but it's somewhat random, and usually only after the car has been driven and the engine is hot...
I'll get in, turn the key, and all I get is a click....usually, I can get it to crank after 3-4 tries, but it's damn annoying, and I'd like it fixed....
Year: 1990
Make: Chevorlet
Model: Z-28 / IROC-Z
Color: Artic White w/ Gold decals
Engine: 5.0L V8 TPI
Trans: 700R4 Auto w/ Overdrive
Wheels: 16" 1992 Z-28 rims (w/ white trim)
Tires: Z-rated Fulda Extremos 245/50/16s (new)
Extra: Power options, T-Tops, Tinted Windows
Mods in progress: Borla stainless steel exhaust, Chrome Headers, Ram Air....
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
