Stall out when I stop
Old Aug 13, 2001 | 09:42 AM
JSweet's Avatar
I have an 85TA with a SBC 400 that stalls out every time I stop in a hurry. The motor runs great other wise. I have checked for vaccum leaks check the break booster. this only happens when the car is moving it will idle for days and I can put my foot on the breaks with no problem. Does anyone know what this is? Idle is about 650rpm.
85 T/A sbc400,edelbrock tes headers,061 heads,3in. exhaust,flow master,k&n air filter,holley 700dp,weiand stealth intake,comp cams 270 cam
Old Aug 13, 2001 | 10:11 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Does It Also Want To Stall Out Around A Hard Fast Turn? Check You Float Level And Correct It. Other People Have Had The Same Problem On This Board. More Than Likely This Is Your Problem.
Old Aug 13, 2001 | 10:36 AM
Swede's Avatar
<font face="Verdana, Arial" size="2">Originally posted by mystikkal_69:
Does It Also Want To Stall Out Around A Hard Fast Turn? Check You Float Level And Correct It. Other People Have Had The Same Problem On This Board. More Than Likely This Is Your Problem.</font>
What do you mean by floatlevel?
Old Aug 13, 2001 | 12:28 PM
Russ-So Cal's Avatar
Swede,
Do you have a carburetor car? If you do, the float level is critical. If the level is set too low, the engine will starve for fuel. If it is too high, the fuel will leak into the venturi through the jets. If you have a fuel injected car, it doesn't matter because you don't have a float.
Old Aug 13, 2001 | 09:32 PM
gmanuel's Avatar
If this is an auto tranny check out the torque lockup switch.
Old Aug 13, 2001 | 09:52 PM
iroc5speed's Avatar
also check for vacuum leaks. my car died like that with a new carb because of vacuum leaks.
Jlanz55
Sep 29, 2015 08:55 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
tattmann
Sep 27, 2015 05:20 PM
ironbmt
Sep 27, 2015 06:00 AM
lanceflame44
Sep 25, 2015 12:28 PM
