MSD....Spark Plugs?????(hesitation)
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
Well my MSD 6A and Coil should be in this morning, yay!
Ok, I have a pretty good hesitiation when there is a big load on the engine or when the Tq converter is locked up in OD when I'm cruisin' down the highway and I give it a little juice. I know its not the tranny cause the rpms arnt picking up when its hesitating, so I'm almost sure its the worn out ignition system. I checked a few of the plugs and didnt notice anything out of the ordinary except that they looked a little white, but nothing too bad. What I was going to do is put the coil and box on it and see if the hesitation goes away. If it doesnt go away them I will just go ahead and start with checking all of the plugs and then move to the plug wires (although those are pretty new MSDs). Do you see this as being the proper way to go about fixing the problem, or what would you do different? Also if I get new plugs, what would you recommend?
j.wolfe
_ ____ _
91 GTA L98
Best time: 14.389@95.49 (VIR)
"...Deception..." Brandon Sloan * ...wounds heal and chics dig scars...
j.wolfe
_ ____ _
91 GTA L98
Car: 99 Formula
Axle/Gears: 342
Check the condition of the plug wires. If they are laying on a heat source they could burn and become cracked. This happened to me twice, the last time I couldn't figure out why my car was missing, I figured I would change the plugs and in doing so I noticed that my #8 plug wire was burnt and cracked. Just something to check.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
Car: 79 Camaro RS
Transmission: TH350
Mark,
Hey I bought my GTA down in Prince Frederick January of last year!
j.wolfe
_ ____ _
91 GTA L98
j.wolfe
_ ____ _
91 GTA L98
yeah check your wires. also make sure that your timing is set right.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei
'95 3.23 rearend
hotchkis rear suspension
'86 IROC 5-speed
305 LG4
msd pro billet hei
'95 3.23 rearend
89 formula TPI
Sep 7, 2015 11:06 AM
