how would this cam perform on a tpi car
Old Aug 12, 2001 | 02:04 PM
u r sofa king we tah did's Avatar
Advertised duration: 292 intake/292 exhaust
Duration at .050 in. cam lift: 234 intake/234 exhaust
Gross valve lift: .488 in. intake/.488 in. exhaust
Lobe separation: 114 degrees
this is for a slightly ported tpi, possibly will be siamesed when i do the cam install. what do you think.
Old Aug 12, 2001 | 02:35 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
That's the same cam I'm going to run... Summit cam eh?
It's really big for a 350 TPI. I was told to use that cam because my compression is a little too high (11:1) and I need to bleed off some low rpm pressure to stay out of detonation. I'm also at 388 cubes.
Your going to need higher compression or it will be very soggy down low, need 3,000 stall and deeper gears. I'm going to go with a full siamese setup again since it worked great on my 'bird. 58mm throttle body and I'm going to have to work out the chip details...
Long tube runners are going to kill it though. Figure if you have 9.3:1 compression (stock) and long tube runners, the cam is going to kill the bottom end and the runners are going to choke the top...
Old Aug 13, 2001 | 08:57 AM
im running a 355 with 10.2:1, think that would be enough? btw, how is the quality with that cam.
[This message has been edited by u r sofa king we tah did (edited August 13, 2001).]
Old Aug 14, 2001 | 02:31 AM
JoelOl75's Avatar
Should be so-so in the low vacuum on a 388 is only around 10"Hg, so it will prolly be less in the 355. I would step down a size, but it's possible to run. In a 388 it makes around 450hp@5500 and about 470lbs-ft torque around 3,200rpm with a 'fair' idle (The 114LSA helps, but not much).
I can't tell you from the butt dyno since the motors installed on my back porch still...
[This message has been edited by JoelOl75 (edited August 14, 2001).]
Old Aug 14, 2001 | 02:38 AM
Jester's Avatar
I'd say it's too big. The computer definatly won't like it....I dunno if you could get it to run right even with custom chips..maybe.
Even if you could get it to run right...it's a bad mismatch. the effective RPM range on a cam like that is way to high for a TPI car. At a ballpark guess I'd say the powerband on that is about 4000-6500. TPI cars are dead by 4500...choose a cam with that in mind.
With a LSA as high as 114..it won't bleed off all that much pressure either.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
86IROC112
Aug 17, 2015 02:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
