Battery? Alternator? Car Has trouble starting
Old May 5, 2005 | 11:02 PM
JoNalzy's Avatar
Car: 85 Camaro
Engine: 305 V8 5.0 L
Transmission: 700r4, shift kit
Recently my car has had trouble starting. Will start sometimes and sometimes not. If it doesn't start and I jump it, it will start back up, turn it off and 15 min later it won't start again. Is my battery not holding the charge? I am getting it tested tommorow, but I want more opinions. I tested the alternator by starting the car and unplugging the negative plug of the battery and it still ran and my lights aren't dimming or anything. So I believe it isn't the alternator. I would just like more input. Tommorow I hope to fail the battery test and hope that a new battery solves the problem.
- Josh
Old May 6, 2005 | 03:59 AM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Put a volt meter across the battery terminals with the engine running and you should see a voltage somewhere between 13.5 and 15.5. If you do, the battery is more than likely done for. Sometimes when your starter motor is giving up the ghost it refuses to turn without a "kick up the butt" from a second battery, but I wouldn't worry about that until the battery test tells you everything you need to know.
Old May 7, 2005 | 05:30 PM
JoNalzy's Avatar
Car: 85 Camaro
I bought a new battery and it is all better now. Thanx for the help though.
Old May 7, 2005 | 06:36 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
it could of been that you had a loose connection?
bryan623
Mar 22, 2021 06:43 PM
midge54
Dec 27, 2019 04:14 PM
killer777
Aug 8, 2015 02:47 PM
