HOW DO I GET RID OF A CODE 34
Old Aug 13, 2001 | 09:05 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
The car keeps shutting off after i adj my tps to 54 or to 56 the car stumbles if i dont give it gas
1986 TPI 305 TRANS AM
Old Aug 14, 2001 | 12:17 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
You may have a vacuum leak or a bad MAF sensor.
Old Aug 14, 2001 | 12:27 AM
jaymz's Avatar
one other thing to check is the relays for the maf power and burn off be sure they are the correct pn. On my 86 IROC the power relay was wrong from the factory.Gm has a TSB on this problem.hope this helps
Old Aug 14, 2001 | 10:50 AM
Drakar's Avatar
I second the relays, I had a code 34 and 43 and replaced the relays, reset my computer, no problems now no codes and the cars "feels" better. Plus replacing a relay is like 20 bucks total and 5 min, maf is 300-500 from what I hear and well .... if you don;t have to you don't want to.
my .00000002 cents (damn exchange rate)
1989 GTA 350 TPI
Stock:
- T-tops
- Dual cats
- 9-Bolt 7.75" Rearend
- 3.27 gears
Mods:
- Dynomax Super Turbo Muffler
- K&N Air Filter
1992 RS 305 TBI - Sold
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
