87 TPI 5.0 rough idle/stalling and pinging
Old May 6, 2005 | 05:06 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Guys, I'm sure it's been talked about, and I've searched for a while...
My 87 (70,000 mi) pings upon acceleration, even on 91 octane, and idles up and down, occasionally stalling. This car was maint-
ained by GM very well......
Where to start? I've already changed the fuel filter and air filters....
Any help will be greatly appreciated.
Old May 6, 2005 | 09:08 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Egr valve? Use premium gas? Checked knock sensor? Cleaned IAC?
Old May 9, 2005 | 09:52 AM
'Shifter's Avatar
Car: 87 Z-28
I do use premium gas all the time, but I'll check out the other parts-
Thanks for the response!
Old May 13, 2005 | 11:13 AM
89Z's Avatar
89Z
Car: '89 IROC Z
Engine: TPI 305
Your timing is advanced too far.
Old May 13, 2005 | 01:37 PM
'Shifter's Avatar
Car: 87 Z-28
Nope, timing was my first thought....it's dead on at 6 degrees BTC
at idle.....
Old May 16, 2005 | 06:31 AM
89Z's Avatar
89Z
Car: '89 IROC Z
Engine: TPI 305
Try 2 or 4 degrees BTDC to see if it makes a difference. Sometimes some engines will run better when the timing is slightly off of the manufacturer's specified value.
Old May 16, 2005 | 06:46 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Have a look at your cap and rotor. My 87TPI seems to eat those components within a year. Will ping under heavy acceleration till I put on a new cap and rotor. Then it's ok for another year.
Old May 16, 2005 | 01:14 PM
sellmanb's Avatar
Car: '86 Berlinetta
Simple things that make the car run lean.... vacuum leaks.... check your O2 sensor as well.
Also, if you havent given it a tune-up recently then you might want to give it the whole once-through.
but... Vacuum leak is my vote.
Old May 17, 2005 | 05:39 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
I agree vacuum leak as well letting unmetered air into the car causing lean condition. lean causes combustion temps to be high which will lead to detonation
your car should run justfine on regular gas and really should only use premium if you have higher compression or advanced timing otherwise it does nothing for your car
another thing you might want to check though is wear in the distributor. take the cap and rotor off again and wiggle it there should be no play. it might rotate which on my car is normal but don't know about yours but it shouldn't fee sloppy and move side to side
what this will cause is your timing to bounce around which might cause some detonation issues
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
