Fans won't work??
Fans won't work??
My car has dual fans, they're not working. If I'm not mistaken the driver side fan comes on first, then the pass side when the car gets hotter. Well the driver side fan doesn't come on at all. I just changed the fan switch but it didn't fix it.I tried just grounding the switch wire, turn the key on and only the passenger side fan runs. I'm lost now so any help will be greatly appreciated.
91'1LE Z28
K&N Filter , Headman Headers & Y Pipe. Invisable cats, Flowmaster 40 series.(just getting started)All show with a little bit of go.
91'1LE Z28
Fusible link?? did you just replace it? where do i get one? and thanks alot!!it was almost a lousy weekend.
91'1LE Z28
91'1LE Z28
Car: 91 RS Convertible
Engine: 305 TBI
I don't have dual fans on my car, but......
when you grounded the fanswitch wire proves your fan switch is shot.
The other fan should come on during A/C operation only.
turn on the A/C and the other fan should come on.
If you just replaced the fan switch then you might have put on too much teflon tape or the fanswitch is not gorunding or defective.
Two bitz from sunbitz.
91 Mystic Teal RS Convertible (1 of 5,000+ made in '91)
Stock 305 TBI, Auto Trans, Stock Rear End
Stereo
Nakamichi CD-35z, Infinity Kappa Series 4x6 & 5 1/4" speakers, Fosgate 12" sub in a custom box, 200watt amp for the sub.
Future Mods & Add Ons
Stereo
- Infinity Basslink
- Hooker Headers
- 3" Exhaust using Flowmaster 80 series muffler
- MSD Ignition
- K&N Filter
- Some Suspension Improvements
1992rs/ss
Jan 31, 2025 05:10 PM
eightsixseven
Dec 16, 2024 01:50 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
