Removing excess stuff
Old May 10, 2005 | 11:37 AM
I-Roc with my Z's Avatar
Car: 1989 Iroc_Z
Its about hightime I start removing things that clutter my engine such as A/C, I want to remove my whole washer system but I am having a hard time finding the washer pump, is there even a washer pump. I try to follow the plug that plugged into the fluid container, that is taped in a wire jacket with about 5 other wires so no luck there, I try to follow the washer hose but it goes into firewall. Anyone help me? Or describe what it looks like. I think i see it but I could be wrong, to mee there are too many wires going into it to be a washer pump. I dont have a pic but its on the firewall, next to brake resevior, it has some black thing, with a silver clyinder attached below at the bottom.
Old May 10, 2005 | 01:20 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
The pump is attached to the bottom side of the washer reservoir isn't it?
Old May 10, 2005 | 01:40 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Wiper Motor "Box" has a small clip on the frontside, then pull down
You just saved 5 ounces!!!
Old May 10, 2005 | 01:54 PM
Car: 1989 Iroc_Z
Its not that I saved "5 ounces" its that I am removing excess stuff that clutters the bay.
Old May 10, 2005 | 09:03 PM
xandersdad's Avatar
Car: Now Camaorless
One question.....If you can't find something (washer pump) then how is it cluttering your hood? What if road spray gets on your windshield?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stryker412
Sep 7, 2015 09:11 AM
rjcme
Sep 5, 2015 01:23 PM
Jetmeck
Sep 4, 2015 12:29 AM
