ZL1?
Old Aug 16, 2001 | 04:38 AM
DualCarb's Avatar
ZL1?
The ZL1 engine used in the 2000 camaro ZL1 concept, will it be for sale, block, heads, cam, cranks, etc.... tks
Old Aug 16, 2001 | 08:17 AM
RW91B4C's Avatar
I think thats a 572ci in the concept.
But the 427 should be though GM.
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.47@129 1.55 60FT. ON MOTOR - ET-STREETs w/MUFFLERS
Old Aug 16, 2001 | 09:59 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
If you feel like spending a couple grand. Call MTI or ARE and ask for a 427 or 422 or all-bore 383, maybe a 360. All come with heads, cam, crank, pistons, etc, etc for the long block but i believe they are minus the induction. Might be better off calling SDPC and asking for the LS6.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old Aug 16, 2001 | 04:51 PM
DualCarb's Avatar
I know its 572ci, is that the size or the bore like a 350 to a 383 strocker?
meeklay812
Oct 1, 2015 03:46 PM
lt1z350
Aug 28, 2015 05:57 AM
bphage
27
Aug 9, 2015 12:31 PM
Nelz
Brakes
Jan 12, 2013 02:56 PM
