Specs on L98 heads..
Car: '91 RS, F41
Transmission: WC T5
Does anyone have the specs on stock L98 heads? Like intake runner size, combustion chamber size, valves etc...
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Valves are 1.94 and 1.50 the chamber is a nominal 64cc's the intake runners are about 165cc's
Transmission: 4L80E/4L80E
Originally posted by cormyr
actually the combustion chamber is 58cc.
Car: 82 Z28
Transmission: TH350
actually the combustion chamber is 58cc. the runner volumes are 163/58 and flows 186/152cfm @ .400 lift
Car: 89 Formula 350 WS6
Engine: 383 miniram
ahh, indeed. i know the accepted terminology for the iron heads is L98 but i believe B2L is what GM called them. L98 refers to aluminum heads. feel free to correct me if im wrong.
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
To add to what's already been posted, L98 heads are in (at least) two forms:
083 casting number, iron head, rounded rectangle exh port shape (as used on L98 Camaro/Firebird, Fcars).
113 casting number, aluminum head (1990+ version), raised D-port exh shape (as used on L98 Corvette, Ycar)
There may also be a 3rd head, also in aluminum because I think the aluminum L98 heads were available as early as 1986. EDIT: the first aluminum heads (1986) on the Vette had the same intake/exh ports as on the iron head. In mid-1988 GM altered the exhaust port on the aluminum by raising it (less abrupt turn to short side radius) and making the short-side into the D-shape to reducing backflow (flow reversion) into the head. Both helped the exhaust side to flow better. The data in Vizard's book is from the 88+ aluminum head. He further said that early and late versions can both be ported to the same flow, so the base casting remains the same --- but the stock flow numbers do not.
Here's the stock head flow data (peak values in cfm). All have 1.94"/1.50" valves int/exh, as listed with the casting number, head material, and peak flow values in cfm, and last is the source for the info (most are 3rdgen sources, plus CHP and Vizard):
083 iron L98 head: 185 intake; 106 exh (smithtc)
083 iron L98 head: 194 intake; 118 exh (rhuarc30)
083 iron L98 head: 202 intake; 141 exh (F-BIRD'88)
113 alum L98 head: 199 intake; 149 exh (Chevy High Performance)
113 alum L98 head: 182 intake; 145 exh (Vizard book, p124,127)
113 alum L98 head: 193 intake; 162 exh (GMHTP, 1.94/1.50)
The intake flows seem to be about the same, iron vs aluminum. The alum heads are better on the exh side.
F-BIRD'88 iron head data is substantially higher on both int and exh, be he pretty much said the same thing himself: "I get much higher numbers. Have so on numerous different sets of like heads". He was probably commenting on ported heads but his stock 083 numbers suggest a similar trend given that the same bench was used.
CHP's measurements also showed superior stock intake flow which makes me wonder if GM revised the 113 casting from the 1991 publishing date in Vizard's book, to 2002 (?) when CHP did their measurments. CHP's production L98 alum head specs and flow are here.
EDIT: according to the GMPP web pages, the 113 casting was retooled into a new 113 casting, so I wouldn't be surprised if GM altered it for better stock flow, which would explain why GMHTP and CHP's numbers were better than those measured by Vizard. That also means that you have to be careful in comparing the flow of the 193 castings (which were never updated) with those of the L98 aluminum heads because there are really 3 versions of the 113 casting: 1986-1988 (same as the 083 iron), 88+ (raised D-port exh), and sometime in the 1990s-2000+ in the re-tooled form having a better valve seat on the intake side. So that really means that there are three different flows possible on 4 sets of stock L98 heads: 083 iron, aluminum clone of 083 (used 86 to mid-88), late-88 alum 113 casting, to early 90s, and then the newest aluminum (113 casting). The 083 iron should equal the 86-88 aluminum; the other 113 castings show progressive improvement on the exhaust side (first 113 casting) and more recently to the intake (early 90s revision to the 113). At least that's how it looks based on what I've been able to find.
I think the only other detail is the combustion chamber on the 083s is 64 cc nominal, while the aluminum heads get 58 cc. IIRC the port volumes are very similar between iron and aluminum.
So the stock flow numbers on L98 head depend on whether they are iron, or early or late aluminum. The intake flow seems fairly consistent for either iron or aluminum and falls in the 180-190 cfm range for peak flow (at or above 0.500" lift). The exhaust flow looks like it will be around 120 cfm for all iron or early (86-88) aluminum heads, and 150 cfm for late aluminum heads.
HTH.
EDIT: per Swapmaster's post:
HTH.
The cast numbers are 14101128 for the 86-87 head with standard exhaust ports and 10088113 for the 88 up raised "D" shaped exhaust ports.
Both heads have the same intake runners that flow 185cfm.
Engine: 383 miniram
Originally posted by ME Leigh
He said stock, and this a 3rd gen site so they would be cast iron L98 heads, with nominal 64cc chambers.
Not from the factory. A Firehawk is hardly a factory 3rd gen.
Engine: 383 miniram
Since GM, in its infinate wisdom, called two different engines (Vette or f-body) the same thing (L98), we just need to be specific which one we're talking about when we ask such questions.
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
i'll just say youre right because if you're part of the thirdgen.org oligarchy youre right no matter what. i guess that makes me wrong.
I've been on this board for four years now and Tim (five7kid) has never used his position as moderator to legislate anything, other than an end to a bad thread. You can trust him
Car: 1991 Trans Am GTA
Engine: 350 TPI (L98)
Transmission: TH-700r4
Weird.
Car: 87 Trans-Am
Engine: 350 cui TPI Chevrolet, MODIFIED
Transmission: WC T-5 with Modifications
Axle/Gears: 3.73 w/ Torsen Diff.
Re: Specs on L98 heads..
1984 - 1986E Corvettes used a cast Iron head with the last three digits of 624: 2.02/1.6 Valve sizes with 76cc Chamber
1986L and later Corvettes Used an Aluminum Head with the last three digits of 128: 1.94/1.56 Valve sizes with a 58cc chamber. These heads were the base of the common ZZ4/H.O. 113 heads.
Car: 1972 nova
Transmission: 350 turbo
Axle/Gears: 3:08
after all that im sooooooooo cornfused can someone tell me if the iron 083 heads R any good ??? MY DRIVER 1972 NOVA
I plan to pull my 350 and build during winter ,,I plan to install fresh{{ 283/200HP 9.25 compression stock}} I want to change heads,intake,carb,cam, like to know what COMP & HP CAN I REALIZE WITH 083 HEADS W/ TORKER 650 HOLLEY & ISKY 270 MEGA 465 LIFT 108 LSA and headers can anyone on here advise with these changes what CAN i EXPECT FROM THIS SET UP ALSO LIKE TO GET A LITTLE MORE COMPRESSION IS HEAD GASKET A OPTION IF SO WHICH GASKET U SUGGEST???
THANKS SWBOWTIE72
THANKS SWBOWTIE72
Car: 89 IrocZ
Engine: L98-ish
THANKS SWBOWTIE72
THANKS SWBOWTIE72
You'll lose compression ratio...thinking the 283's were using 56 or 58CC heads, 083's are 64cc,
The 113's would afford you getting into the range..and if the block were decked a tad, and mill the heads...you might find what you're after.
Thing is, you have the engine, spec's, etc in front of you, you will have to be the one to decide on CR you want, and how it all fits together with a particular CC'ed head, and what else you may have to do to achieve your goals.
Car: 1972 nova
Axle/Gears: 3:08
thanks I would like to see 10 but maybe tops may be 9:5 with 083, can u see this a realistic #
what if milled heads & gasket u think could do any better ?
advise a dummy thanks for ur help steve
