Confirmed noise coming from bottom end...
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I had my 77K mile 305 TBI Camaro in the shop yesterday for them to put in my Jet Fan Switch and Thermostat. They also replaced my whacky oil pressure unit. Ever since I got the car it has had a strange noise coming from somewhere in the engine really only audible at idle. It doesn't sound metallic, and like I said, it is heard strongly at idle sounding like a combination of a tap, tick, and puff. It does not get louder as the RPMs go, and I can't hear it during regular driving, only at idle.
My mechanic confirmed that it sounds like its coming from the bottom end of the motor towards the back near the bellhousing. My oil pressure never goes below the middle mark and at cruising speeds stays at the mark between 30 and 60psi (stock gauge). I have used 5w-30 Valvoline Max Life since I bought it. The guy gave me a can of some engine treatment that I put in to see if it quieted the sound. It quited my lifters a little more, but the noise from the bottom end is still there.
They didn't really seem too concerned about it, I was kind of in a hurry and didn't have time to talk much, so I will talk to him again today. I need this car right now until my GTO comes in, what do you guys think about this? Will I be ok, driving this car like normal?
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Re: Confirmed noise coming from bottom end...
I wish I could help.
Car: 1992 Camaro RS
Engine: 305 L03
Thanks for the reply man. Yeah, this has been eating at me since I bought the car. Its very strange, I can only hear it at idle or near idle, when I rev the car or under normal driving I don't hear the noise. Car consumes no oil, idles steady, and oil pressure never drops past the first yellow mark at idle and while driving stays between 30 and 60psi. The transmission makes all kinds of whiney sounds and the clutch needs attention for sure. So, I guess it is still a possibility it could have something to do with the flywheel, clutch, transmission to engine stuff. I have never heard a spun bearing or rod knock so I don't really know. But I thought they got louder with RPM and mine does not. Anymore suggestions from anyone?
Car: 1991 Firebird
Engine: 3.1L V6 MPFI
Transmission: 4 Spd Auto + OD 700R4
My engine has a low end knock/tick, too. Since I bought it. I'm also leaking oil so I'm assuming its a rod bearing or the main bearing. I have not had it checked out yet.
Car: '86 Berlinetta
1) Make sure your dampner is tight and not wobbling or missing a bolt or something of that sort.
2) Take off the inspection plate and make sure all the flywheel bolts are in (if thirdgen manual trans have inspection plates? Never seen them before...
To Grizzly_Addams... an oil leak is more a sign of a gasket needing replaced than a rod bearing going out. A bearing w/ excess clearance will give you low oil pressure, not leak oil.
Check the typical places for oil leaks... intake manifold gasket, valve covers, oil pan, oil filter, and oil pan drain plug gasket.
)To Grizzly_Addams... an oil leak is more a sign of a gasket needing replaced than a rod bearing going out. A bearing w/ excess clearance will give you low oil pressure, not leak oil.
Car: 1992 Camaro RS
Engine: 305 L03
Grizzly,
That is not low oil pressure, that is normal. Now, anybody that has had a rod or bearing knock/noise, what exactly did it sound like? Could you hear it throughout the RPM range or just at idle? Did it get louder with higher RPM?
Car: 1991 Firebird
Oh. Well, at least my oil pressure is OK then. But, i hear it at idle, and when I drive it gets more frequent. Not so much louder. Just seems to get w/ the RPMs.
Car: '86 Berlinetta
Car: '86 Berlinetta
Grizzly,
Grizzly,
The knock sensor goes crazy if there's any knock and retards the timing like a ****....
though I gotta hand it to chevy... I dont know many other motors that with 4 of 8 rods bearings being spun could I still go 55 on the freeway and get home about 12 miles away from my house.
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
sellmanb;
ditto on chevys always gettin ya home!
only been stranded one time out of many!that was a thrown fanbelt in the middle of nowhere,found one in a farmers barn,and was back on the road in less than an hour!
v8nate;
go to a pharmacy and get a stehescope,pull the piece you would apply to someones heart and insert a bolt in the rubber hose(a little oil or vaseline helps).then start listeng to various areas of your motor until you pinpoint the sourse of the sound!
it's a very enlightening experience!just be VERY careful when you are around moving parts!no jewelry,loose sleeves,watches,long hair or nuthin!i've seen an aluminum flex fan do extreme damage to a friend's elbow.........
anyway i would get the cheapest one i could find,nuthin fancy needed,but if you can't find it with that,it's an exhaust leak.
Eric
v8nate;
Eric
Car: '86 Berlinetta
Exhaust leak? It's really a very clear knock coming from the engine. Could it really be an exhaust leak?
Very possible.
The three most common "feigned knocks" are:
Exhaust leak
Flexplate/Flywheel broken
Spark knock ( too much timing, needs a tuneup, running too low an octane gas, etc)
I'd doubt yours has a broken flexplate or flywheel since you didnt say anything about it not running right, it just has a noise that you dislike...
spark knock would also make a big difference in your performance.
And while an exhaust leak will hinder your performance, it hinders your gas mileage more, and the performance loss isn't too noticeable unless it's a huge leak... most the time it's like driving around on a hot day kind of power loss... (because the air is less dense)
I'll concurr with Sleeper86 though, the best way to find out is to just get a stethescope and prod around... or take an old piece of heater hose and put it around areas and put your ear to the other side... and always use caution when working on cars, whether they're on or not... you never know when you might just happen to ground out the wrong wire or what be it and start the fan, or spin the starter on accident, etc...
Car: 1991 Firebird
Originally posted by sellmanb
Very possible.
Exhaust leak
Very possible.
Exhaust leak
My performance? Pfft. 4 cylinder cars kick my ***. It has no get up and go, especially at operating temperature.
I'll check with a stethoscope, and I hope it's an exhaust leak, because like I said, sounds very distinctly like a hard knocking in the engine.
Car: 1985 Z28 Coupe
Engine: Carb'd LB9 .030 over
Transmission: TH700R4
Axle/Gears: Posi 3.42 10-bolt
i had the exact same problem , turned out the bolts between the torque converter and flexplate where loose and made little egg shape holes in the flexplate so everytime i was in gear and at idle it would knock, once i was driving and everything was spinning it would stop. i see you have a manual and not auto, but it's worth taking a peek. good luck!
Car: 1985 Z28 Coupe
Originally posted by 84z28350
You do realise this thread was 4 months old!?!?
Probably killed 2 motors since this one
theshackle
Sep 17, 2020 08:26 AM
