new 58 cc heads on a motor that had 64 cc. will it hurt it
Old May 11, 2005 | 11:37 AM
ar_mcadams's Avatar
Car: 91 camaro
Transmission: auto 700r4
I have a motor with 6k miles on it with 64 cc heads and want to put some alluminum 58 cc heads on it, but I dont want it to start burning oil. I put some on a motor with 80 k on it once and had to rebuild the thing because it started burning oil badley. Anyone else had this problem.
Old May 11, 2005 | 12:00 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Used to be common back in the old days to do a valve job and start using oil, I suppose worn cylinders and rings against higher vacuum and compression. With your engine fresh I'd sure think you'd have no problems with the swap.
Old May 11, 2005 | 03:54 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
The size of the chamber has nothing to do w/ why it it burning oil. Why did you put leaky heads on a motor?
Old May 12, 2005 | 08:02 AM
ar_mcadams's Avatar
Car: 91 camaro
the heads I put on it had been vacume cheched after they bad been rebuilt. I put them on and within 300 miles it started burning oil. They did have new positive seals also. Just dont want to run into that again. I have heard of otheres having this problem before but dont understand why it would happen.
Old May 12, 2005 | 10:32 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
More likely it was something that was or wasn't done when the heads were changed than changing the heads themselves. Like not properly cleaning the pistons/cylinders before putting the new heads on.
I changed heads at 141k miles, it's over 169k now. Oil comsumption has actually gone down.
Old May 13, 2005 | 01:49 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
i believe vaccum testing only relates to the relationship between the valves and their seats.nothing to do with valve guide clearances.unless the guides are severely worn.did you have the guides knurled or replaced?teflon seals definately use more oil than pc style or o-ring seals.
Eric
Old May 13, 2005 | 07:47 AM
ar_mcadams's Avatar
Car: 91 camaro
I was told teflon seals use less oil. In fact I was told that teflon seals actually seal to good and deprive the guide of lubrication. The guides were new.
evilstuie
Jan 9, 2020 08:29 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
